Big Twin 35
Savyman
Hey everyone,<br />Im working on a Evin.35 Big twin Fires right up<br />and runs but no water anywhere gets hot to touch.<br />I pulled lower unit im finding alot of carbon pieces and the pick up tube seems clogged.the wpump seems fine.How do i unclog?Anyone?please :eek:
Paul Moir
Re: Big Twin 35
Hook up an old garden hose to the tube and blow it out with street pressure. You'll find that the OD of the tube is a close fit for the ID of a garden hose. Use electical tape to make up any difference if necessary. The water pump must be submerged at idle for it to work correctly on these old Big Twins.<br />Good luck!
Savyman
Re: Big Twin 35
Hey thanx Paul,<br />i was alittle worried about the carbon is it possible to clean out without disassembly?ill try the hose were will it come out?Do these hav a tstat or somewhere it could be clogged up?i took a small hand pump with hoses and pumped up tube ,wen line is pulled it drains out tube bottom.its a 1957.
Paul Moir
Re: Big Twin 35
If it's a '57, then there is no thermostat. It did not get one until '58. Otherwise, it would be under the plate on the head held on by three screws.<br />So for a '57, there should be no restriction felt at all if you were to blow up through the water tube. (Use a hose attached. :) )<br /><br />The water should come out of the large hole on the back of the midsection. I belive some is also supposed to come down where the exhaust goes. If this doesn't work, and shoving a wire up the tube doesn't either, then you're going to have to remove the head and/or exhaust cover to expose the passages. But I don't think it'll come to that. <br /><br />Oh yeah, if it was a '58-, then you would have two water tubes for the water pump in the midsection. :) <br /><br />I don't understand how carbon could have gotten into the system, unless it was from crud floating around in the bucket it was tested in. It's not chunks of an old impeller that flew apart is it?<br /><br />If your impeller is ok, then it's arms should stick straight out when you take it out of the housing like the one in this picture:<br /> Picture 1<br /> Picture 2<br /> <br />Good luck!
Savyman
Re: Big Twin 35
Thanx again for great info,<br />Yea 1957,I Salvaged this motor.Up in the top of<br />casing were the tube goes in and the shift link is theres black carbon looking stuff.It was all over in the wpump area.Appears to be were blockage is.Looked like somone changed the impeller and found it was not the problem.i hope i can blow out.I need to boat and fish,not be a mechanic.
