1970 Evinrude Big Twin 40 hp (40052A). Removed starter in order to remove carburetor. Noticed the screw in the hole circled below was stripped or wrong size. Just loose in the hole. Thought it didn't matter much since only impact would be on starter bracket. Fired up motor yesterday to decarb with SeaFoam and noticed spark deep in the hole. Shut off and found a screw with similar threads and closed the hole. What was I seeing? Is this the manifold or part of cylinder.
Thanks,
Ron
Thanks,
Ron
