Bilge Plug for VIP
Seon
I'm posting here because the VIP board has very little to no activity :(.
I have a 2001 VIP Baystealth center console that has a "plastic" plug with an o-ring. It's does not have the standard brass 1/2 IPS threads so rather than waiting for me to mis-place or lose it, I thought I'd ask where I can purchase a spare plug? There isn't a VIP dealer here locally so any help ise greatly appreciated.
a70eliminator
Re: Bilge Plug for VIP
If Iboats doesn't have a plug for your boat I'd be surprised, I've only seen two types either screw in or expansion type, can't imagine anything else sorry, maybe somebody else can help.
Seon
I..I've only seen two types either screw in or expansion type,
Here's the VIP plug I'm referring to.
Here are the THREE plugs...VIP Plastic Plug, Brass Plug and Expandable Plug.
The tab on the VIP plug is inserted in the drain hole which holds has the plug "dangling" place when unscrewed... that's one reason why I'd like to have a spare for a back-up :rolleyes:.
Any help??
a70eliminator
I see now, mama has a lemonade jug with a plug just like that one, or very close anyhow, try a plumbing outlet sore for a nylon plug.
smokeonthewater
I've seen a plug of that style at walmart but it had differsnt threads than my jet n cat... I contacted anapolis performance sailing and ordered 4 plugs from them.... they may be able to help you too
boat1010
Does the go in from the outside of the boat? Can you just replace the whole thing with a brass one. Also you might check the plumbing section at Manards. might find something there.
Seon
Smoke, thanks for the link. I sent them an email.
BTW I did stop at Lowes, Ace hardware, plumbing supply stores and Orchards Hardware and non carried this plug :redface:.
rda738
on my boat the plug is a 3/4 inch brass screwed from inside through the floor tapered and will not thread from outside of boat have rubber plug compression plug as backup Dave
Seon
I been beating the bushes and found this, of all places on this site. The plug appears to be identical to what I have except for the color.
