My boat, 16' CC w/90 hp Johnson, stays winched up on a buddies dock, when not in use. I pull the drain plug (I have an automatic bilge pump) each time its winched up. The problem: I had bi-lateral knee replacements two years ago, which makes it hard to reach inside the bilge to install the plug, have tried installing it from o/s before pushing the boat in the water, but since the boat's at an up hill angle and the drain hole is so low........well, you can imagine the picture, have almost gone into the water twice before getting the plug in. Give me some ideas on installing something different. Ping pong ball and the cage, rubber scuppers, seacock? I'm about to trailer it home for its yearly checkup since the water temp is coming back-up.<br /><br />B O A T... bring on another thousand
