Bilge Pump 310se
Bio-tech
My lower bilge will only turn on if I engage the manual switch, on the cockpit. There is also a circuit breaker underneath the steering wheel for the Manuel switch. Does anyone know where the fuse or circuit breaker for the automatic wire is located.
bannister
Re: Bilge Pump 310se
it is the same fuse. there is only one power supply.
check the wiring connections for corrosion and the float switch.
TeamPCBeach
Float switch is either bad or fouled. Check to make sure some trash has not gotten in and is preventing the float to raise up and turn the pump on. As Bannister said, only one power wire for the pump.
