mwe-maxxowner
- Joined
- Jun 20, 2012
- 825
Is there any reason a bilge pump cant be used to fill a ballast bag? Put a 12 volt plug on one end and a long enough cord I can lower it into the water?
Bilge pumps don't have the pressure to fill a bag, You need the flexible vane pump for that.
Ballast bags aren't typically pressurized - so you are not pumping against anything but gravity to fill them, no reason you couldn't do it with anything capable of pushing water.
Perfectly fine. Just use a big diameter hose. To empty the bag, put the pump suction onto the bag and drop the hose over the side.
This is what I use for my fatsac
Where did that come from and how much was it? Mainly just investigating use of a bilge pump because I have a spare not being used for anything.
