Bilge Pump Auto or Not
nightstalker
My aft bilge has two wires while my forward bilge pump(which needs to be replaced) has three. The switch on the dash is only a two way (on/off) switch. It turns the aft bilge on and off so I know this pump is working. Does this mean that the rear bilge is strictly on/off and that the forward bilge will not work on automatic? <br />Stalker
Solittle
Re: Bilge Pump Auto or Not
A two wire pump will be controlled by a single on-off switch (1+ and 1-). A three wire pump is for automatic on with a float switch or a on-off switch (2+ and 1-). Most boats will have the automatic pump in the bilge as that is the lowest part of most boats.
profish00
I have yet to find a bildge (FLOAT ) switch that worked a season, although I still have the same working pump
18rabbit
Auto bilge pumps are switched by placing the float switch contact inline with the source.<br /><br />Your forward 3-wire bilge pump is likely designed to be wired into a 3-way panel switch and the pump probably has a built in float switch. At the panel switch, use ‘off’ to isolate the pump; ‘auto’ to let the pump make it’s own decisions; or hold in ‘manual’ to bypass the float switch to activate the pump. Your pump’s wires should be something like: black=common (gnd); brown wire for manual source; brown with stripe (white, yellow or red) for auto source.<br /><br />You should be able to test the pump by applying a voltage source to the brown wire and take the black wire to a common ground.<br /><br /> If your aft pump has a float switch built in it will pump when voltage is supplied only if there is something to pump. Without a float switch it is a simple on/off configuration.<br /><br />You can “T” off the source wire from the aft pump and place an optional float switch inline with the ‘auto’ position of a 3-way panel switch on one leg; and run the other side of the “T” to the ‘manual’ position of the panel switch.<br /><br />Without 3-way panel switches, you can wire the pump(s) thru ignition activated circuitry so they are available for auto function only when the boat is pwr’d on. This prevents an unattended bilge pump from auto starting and draining the battery (bank).
nightstalker
Thanks for the help.<br /> I wired the forward switch to an auto bilge and it works fine. I'll keep the aft switch a simple on/off arrangement.<br />Stalker
