bilge pump installation on phantom 16
5342cook
hi all
I have a phantom 16 that is kept on a trailer out of water and stored with the transom drain plug out of the boat and then that is replaced before launching. On a normal days boating in the sea the boat takes on very little water and isn't an issue. However when the water gets a little choppy (due to a low gunwhale) and people are in and out of the water doing water sports it quickly fills up the bilge. Currently I don't have a bilge pump fitted and due to nearly losing my vessel last week due to water ingress im looking for hints tips and advice on how where and which one to fit?
Pez Vela
Re: bilge pump instalation on phantom 16
The thru-hull fitting for the discharge hose appears to be located on the port side, just aft of the boat's lettering. Double-click the photo for a look-see. I wonder if you've thought of calling Phantom Sport Boats to see how they rig their boats?
NYBo
Is there any sign that there was ever a bilge pump installed? If not, you will need hose, thru-hull fitting, wiring, a switch, and hose clamps in addition to the pump itself. Follow the installation instructions carefully as to proper routing of the hose. This is usually the most difficult part of the installation in a small boat due to the limited space and the flotation foam.
5342cook
your little phantom looks great and thanks for the pic thats helped alot. No old bilge pump fitted so its guna be a first time install. What size pump do you suggest for this vessel (gph)?
5342cook
theres no old bilge pump or signs of one being there so its gonna be a first time install. I was just wondering what size pump i need to fit (gph)?
JoLin
You mentioned that you nearly lost the boat from too much water coming aboard. I'd actually consider having 2 pumps. One small capacity (say, 500 gph) on an automatic switch mounted as low as possible in the boat. That'll take care of rainwater and spray without killing the battery. A second 'big gun' (1500-2000 gph) mounted so that the float switch is a couple inches higher than that of the small pump. It won't go into action at all unless the boat is filling suddenly/quickly, which I assume is what happened to you.
My .02
crabby captain john
Agreed, and wired to separate batteries if there are 2 of those also.
My .02
5342cook
Re: bilge pump installation on phantom 16
well it happened over a period of the day. i was taking a big wave over the gunwhale every now and then and after 8 or 9 of these waves the boat became very slugish and heavy towards the rear however if id had a pump fitted i ciould have pumped it through a few times throughout the day and kept on top of the problem
Pez Vela
I just pulled that photo from the Phantom Sport Boats website, as I do not own one. A single 1500 GPH bilge pump would be the standard size for your boat. The only reason to go smaller would be if space limitations dictate. Add a float switch to the installation and you'll be good to go.
