Bilge Pump Needed on 14' Jon Boat Tracker Topper?
FLHANDSTER
Is it necessary to install a Bilge Pump on board my 14' Jon Boat!?! If so, have any rcommendations?
Why would water accumulate inside the boat!?!
Please advise ASAP.
Thank you!!!
FLHANDSTER
DRAIN PLUG: Insert Inside/Outside
Should the drain plug be placed inside or outside on a 14' Tracker Topper Jon boat?
Does water tend to accumulate inside the boat?
Any tips on draining the water inside the boat (i.e. Caught out in the rain and then wanting to get water out of it upon returning home)?
Is the issued plug sufficient, or should one acquire an after market drain plug?
Any name brands or suggestions for this DRAIN PLUG inquiry?
PLMK ASAP!!!
Thank you!
loose rivet
Re: Bilge Pump Needed on 14' Jon Boat Tracker Topper?
I would consider a bilge pump a safety item if your going long distances from land.
A boat can take on water either from rain or a leak, most likely a leaky rivet or drain plug on an aluminum boat.
If your boat leaks, a bilge pump isn't the fix. Find and stop the leak with a proper repair. The pump is only so you don't sink.
I keep a bilge pump installed on any of my boats with floors since bailing a leak with a bucket won't always work.
Remember adding an electric bilge pump also means adding a battery and switch.
H20Rat
Do you have a battery on the boat? If you don't, I wouldn't add one just for a pump. But on the other hand, if you do have a battery, nobody in the history of boating has ever complained about having a bilge pump and wished they didn't!
In a boat that size, I'd just keep a sawed off milk jug around for a multipurpose bait bucket/bailer.
Home Cookin'
1. Bilge pump or not, always have a bailer on every boat. The home-made scoop is the best for open-hulls like a jon.
2. When you get water in a jon boat, you get on a plane and pull the plug. That's one reason the plug is on the inside and can be manually removed, unlike a smaller bronze garboard plug. In really bad conditions you run with the plug out. Note: the plug should be tied to a piece of string attached to the motor so (a) you don't drop it overboard while running and (b) so you don't lose it.
3. On a boat that size a bilge pump is for convenience, or if you leave the boat moored and can't get to it to bail it out after a rain. As said, that's if you already have a battery; most small boats w/ pull starts don't.
4. if you have a bilge pump b/c you have a battery and you moor it, add a float switch. If you don't moor it and want it for convenience, just have a toggle switch. The less wiring and connections, the better.
5. Note that since you can't run the water out if your motor is broken down in a rain storm, the bilge pump may add a degree of safety, but so does the bailer. Chances are, in really bad circumstances, the bailer will be better. There is no more efficient device than a man with a bailer in a sinking boat.
6. Thiose plastic hand pumps work well, too, and I carry them on my boats with decks as a back-up to the bilge pump, and have needed it once.
AChotrod
If you dont already have a battery just get a empty bleach jug cut off the bottom and a sponge. If its so bad you cant handle the incoming water in a boat that size with a bailer your pretty much screwed anyhow. If you have a battery then I would for sure add one for convenience. I had a small jon that leaked and it was very annoying bailing all the time but never even came close to sinking it.
