Recently I purchased a 1998 aluminum Northwood hull that came equipped with a livewell.
Since the livewell was too small to be anything other than a baitwell and I didn't like the way it was mounted in the hull (as a bench across the rear of the boat), I decided to remove it.
Now I have two problems:
1.) - The overflow hose from the former livewell used a 1.5" hose and has the appropriate thru-hull fitting. My bilge pump uses a 3/4" hose. What can I use to join the two hoses?
2.) There are two holes left behind in transom from where the livewell intake and drain used to be. I need to seal these up. I've one of three ideas I've been kicking around:
A.) Use two thru-hull fittings and tie them together with a piece of 3/4" hose.
B.) Cut a piece of aluminum from the former livewell and have it welded over the two holes.
C.) Use fiberglass strips to shore up the holes.
What would be the best solution in this case?
Thank you.
Thank you.
