Bilge Pump Switch Placement
sailsmanship
I have a Rule 1200 GPH Bilge pump with a separate Rule Switch that I am installing. Question is how close to the pump can you get.
The perfect place where it is at the lowest point and a flat surface is about a half an inch from the pump. If I put it anywhere else it will be at an angle and up. I just don't want the switch to interfere with the pump or visa versa,
Re: Bilge Pump Switch Placement
Ayuh,.... Basically, anywhere so's that the pump don't run outa water, before the switch shuts it Off...
Fireman431
If one has to be higher, make it the float switch. You'll be fine if you have a few inches of water left over. You just don't want the switch still 'on' and the pump running dry.
