IslanderVT
- Joined
- Mar 13, 2013
- 48
We have a 21' Seebold I/O sport boat that I'm currently doing a partial restoration on (gas tank, stringers, bulkheads, deck, etc).
This boat is low freeboard with little safety margin in a swamping situation (ie hose burst, sudden leak, etc). Also I'm moving into a family boating mode...most of the time we've had it has just been my wife and I...now we have 2 young kids...so I'm thinking more about safety and redundancy.
Has a 25 year old bilge pump with manual switch which I'm planning to replace.
I'm also planning a second redundant pump for emergency use.
I don't want to replace rotted wood again...so I never want water to accumulate in this boat...ever.
So the system I'm planning will include:
1) 800 GPH main pump with a liquid switch at the low point of the bilge wired to permanent power and using the current 3/4" hose. Seems like this should not have an OFF switch so it will always pump water from the bilge. This would cover normal water sources...rain, wet swimmers, spray, etc.
2) 1000 GPH emergency pump with a manual switch and using a new 1 1/8" hose and discharge port out the opposite side of the boat. This would only be needed for a catastrophic event (hose burst, hull breach, water over stern).
3) Audible bilge alarm with liquid switch mounted at say 4" level. This would indicate the main pump has failed or is being overrun, such as might happen with a main water line burst. Seen enough cases of this happening and the driver only realizing it after seeing water come up inside the boat that it needs to have a countermeasure.
All 3 mounted on a 1/4" lexan plate (I have some already) with a matching mount plate that is glued to the hull at the bottom of the bilge...attached with wing nuts and with wires and hoses strung such that it comes out as one piece.
Questions:
Anyone have experience with this type of liquid switch? My pumps will be under the engine which is tough to reach with the interior installed, so no moving parts sounds appealing. I've seen some posts about the float type switches failing or getting jammed.
Mayfair Ultima Bilge Switch - Johnson Pump 36303 - iboats
Mayfair High Water Bilge Alert - Johnson Pump 72303 - iboats
Is there any reason to be able to turn off a bilge pump with level switch? I can't think of any except for cleaning/flushing the bilge, in which case I think I'd still want the pump going.
How should I glue down the permanent lexan plate to a freshened polyester fiberglass surface...5200? Peanut Butter?
Any other advice before I start buying parts? Planning for Rule pumps, and perhaps the switches above.
Thanks!
Questions:
Thanks!
