Re: Bilge pump will not shut off when float switch wire is attached.
Float is stuck in the on position. You should have a test knob on it, see if you can rotate it to the down, or off position. If the switch internals are such that whatever position, the pump runs, time for a new switch. Probably time for a new one anyway...
