Bilge pump ?
shebwilly
Hello I just have a quick question,is there a rule of thumb on bilge pumps,in other words,I have a 15'tri-hull bowrider,do I need a bilge pump or are they mostly for bigger boats?
Home Cookin'
Re: Bilge pump ?
like everything with boats, it depends, but probably. If the boat is moored, yes. If you cannot remove the plug easily from the inside, to run water out the boat, yes.
Some boats like whalers and carolina skiffs are sealed hulls and have no bilge below decks, and can be bailed out or are self-bailing; a bilge pump may be handy, but not necessary.
considering size alone, at 15' you are on the fence but if you have a bilge below deck, I'd get one. More important than size is how and where you use the boat.
I was thinking about this just yesterday after a big rain storm--back in the 60's/70's, growing up on the river, many if not most small boats didn't have them, and you just ran the water out after a storm or bailed. You could also ride around after a storm and often see at least one swamped boat, either no pump or dead battery.
Now pumps are better and cheaper, and batteries are better, so like many things, we boaters got along without, but life is better with.
Set up a seperate float switch, wired to the battery. get the kind that's in a box-like housing so something can't fall on topof it and keep it from running. A manual switch at the dash is convenient.
southkogs
Re: Bilge pump ?
My old 15' had one (15' bowrider tri-hull). It was never really a "need," but after getting caught in the rain on the lake it was nice. It also helped quite a bit after we'd been in and out of the boat swimming/skiing - just keeping the bilge dry. If yours sits at a dock a bunch and collects water every now and again, it's probably worth it especially with a float switch. If you trailer it, the pump is probably more of a "extra." I trailer my current 18' tri-hull I/O and it's still more of an "extra," but I do use it fairly regularly when we've been playing a lot.
Do you have to do a full-on "drill a hole in the hull" install if you want one?
