bilge pumps....which one?
IOWA BOATER
1978 Cobalt has origional bilge pump with a float switch and is getting weak - have to push water into it from the outside to prime it. I am going to replace it but have a few questions. The pump is not in the bilge, it is located next to the tilt/trim pump and has a hose into the bilge. Should I replace with same type or put one in the bilge? Also what's good? What do you guys use? Thanks!!!
D
DJ
Guest
Re: bilge pumps....which one?
I like the Mayfair brand with the replaceable cartridges. If your bilge pump occasionally ingests some junk, it wears out the impellers. The Mayfairs allow tyou to replace the motor/impeller assembly.
sea wolf
if it's the original pump how many gph is it? the reason i ask is that most boat manuf. skimp here. they'll put a 500 gph pump in a 20 ft. runabout. what many boaters don't realize is that in a small boat u need a larger pump {g.p.h.} beacause a 20 footer will fill up with water a lot faster than say a 30 footer. therefore u need a pump that can handle a lot of water fast. if the pump says 500 g.p.h., in reality it will only pump say 350 g.p.h., due to gravity etc. if u get a major leak with that size pump, your in deep u know what. just my $.02.
D
DJ
Guest
Sea Wolf makes a very good point. If you have a 500, go to a minimum of 750. If you have a 750, go to a 1000-you get the idea.
crab bait
if you can mount it in the bilge without alot of hassel do it..it aleviates the hose which is the soarse of your problem.. even a short hose causes priming problems.. plus with hose you lose gpm oppose to direct mount ..
araiha
One of the best pumps available is the rule 1500. They have a warranteed one that is virtually bulletproof. Spendy, but I like staying on top with dry feet. <br /><br />I have two 1500 gph pumps in my boat, one forward, one aft.<br /><br />I would put in as much pump as your electrical system and room will allow.<br /><br />Even with my set-up I am only (ideally, actual is less) moving 50 gallons/minute. Still not a lot of water if you take a big slug for some reason.
Spidybot
The main reason for putting the pump higher and using a hose is if there's no room or access is bad. If you want to fit a filter it might be easier on a hose than on a pump housing.<br /><br />If you imagine water constantly coming in through a hole (even minor) in the hull, you'll agree to the posts regarding capacity.
BobZ
Pumps don't handle liquids efficiently on the suction side. They 'push' liquid much better than they 'pull'. <br /><br />That is why most pumps sit down on the hull.
