bilge pumps
barrowgv
anyone know where to find a wiring diagram for the bilge pumps in a Searay AJ with 5.0 mercruiser /outdrive 2001 model. has standard and emergency pump. need especially the connection at the wiring harness in the bilge. i am confused on the wiring colors.
NHGuy
Re: bilge pumps
Check for power at the old pump 1st. Maybe there is an unknown switch or tripped beaker/fuse. Then, when you are sure you want to replace the pump check the power with a tester or a light 1st. You gotta have juice!
Here is a list of wiring colors using the ABYC standards. Pumps use brown. http://www.acbsphl.org/Tips_and_hints/ABYC_Wiring.htm
