Re: Bilge Pumps
Look at some of the pics of floors getting torn up both here and on that shareaproject site to see how they normally are. Normally unless its a boat with a complete upper fiberglass half that fits on the lower half, its just glassed in supports with gaps between them filled with foam. Then some carpeted plywood thrown on top.<br /><br />I think I remember seeing a hull with a totally glassed in floor now that I think about it, was almost like a fiberglass deck under the actual wood one. It still had wood and foam under that though. Kinda sucked cuz it got a hole in the top and the owner didnt notice so every time it rained it filled with water and rotten the underside stuff and the foam.<br /><br />There has been lots of talk of foam in this forum, I think many companies have been using open celled foam which eventually turns into a sponge. Closed cell really is never supposed to do that even if its cut into or sanded to shape. There was a company mentioned here before in another thread that was supposed to have really good long term water proofing. Apparently it only starts to break down and takes on water after years of constantly being in water, which wouldnt happen in a boat unless you have a hole you never fix or something.<br /><br />I'm still not quite getting the idea here, if the floor is sealed where is the second bilge pump going?
