The decking in the bilge was getting a little soft so I decided to make it my spring project to cut it out and inspect. The stringers have some bad spots but they arent completely shot. There was no water under the decking but the glass work was pretty shotty from the original manufacturer. The stringer and floor supports run from the transom to the first bulkhead. As long as I have everything open, I'm going to head and replace everything. This will be my 3rd glass job so I have some experience. I want to make sure I'm doing this right so need so thoughts on my game plan.
There is one main structure stringer against the hull and then the floor support stringers.
Game plan:
Finish cutting the glass off the stringers.
Remove the wood and grind the hull
Replace the main stringer with laminated ACX plywood. Overall size 2"x4". Round over the sides. Or should I use a 2x4 of a particular wood?
Embed with West Epoxy and 406 to make epoxy peanut butter.
Create epoxy fillet on the sides
Let it cure
Replace the floor supports with 1/2 ACX plywood embedded with West Epoxy and 406 and create epoxy fillet on the sides.
Coat main stringer and floor support with epoxy and 17oz biax no mat cloth. Not sure if I should do 2 layers or not.
Then for the decking, take a sheet of 1/2 ACX and coat the backside of the plywood with epoxy and 6oz cloth.
Install the decking once the backside is cured and use 17oz biax no mat cloth over the face and join it to the existing glass along the sides.
Game plan:
Let it cure
