jurgenscraft
- Joined
- Nov 6, 2004
- 227
Hello all.
how do get rid of that typical bad sea water smell in the bilges under the deck of my boat, I do have bilge pumps that remove most of the water that makes it way into the bilges( recent addition) I also have drain plugs tha I use to drain excess water from the bilges I gave one large inspection hatch that gives me acess to the bilge pump area.
the hull of the boat is devided into three compartments along the length of the vessel, the two outer comprtments are foam filled for bouancy and the centre compartment is the bilge area which has polystyrene foam for aditional bouancy the hatch and bilge pump are recent additions and I made up a extractor fan that I have been using to ventilate the centre bilges as well as the foam filled sections under the deck.
Regards William Wright,
