Bimini EYE ENDS
Cortes100
Shot in the dark, mystery part. Looking for a couple eye ends that are offset. So far can only find ones that are centered. Similar to the pic but I want the male tab to be offset to one side.
Anyone know if that type exist??
did you look in Iboats.
however why do you need it offset?
Cortes100
yes I have surfed through the Iboats shopping section and misc online catalogs.
When traveling, I'd like to lay the Bimini down onto the sundeck. The telescopic rear poles let it lower to 18" above the deck, but it would be nice to lay it right down.
I have a side mount deck hinge for the main center post for the bimini. If lowering too far, the main post will bind onto cover snap. The offset eye would give me the clearance needed.
or put a spacer behind your deck hing
