Re: birch ply good for wooden benches?
From a technical stand point there are two basic types of oaks the reds and the whites. There are some interesting off shoots, like the so called evergreen oaks. They're not, they just drop their leaves and sprout new ones, in a few weeks during late winter or early spring, making them appear evergreen. Some of these are superior to traditional white oak.
The whites are denser, stronger and more rot resistant then the reds. The physical structure of the reds cause them to be very porous, which isn't good on a boat, nor helpful at resisting rot. A 1/4" square by 12' long section of red oak, if placed in a container of water, will produce bubbles if you blow on the end like a soda straw. This is a function of it's fiber orientation and causes it to "wick" moisture throughout the piece.
As far as boat builders are concerned, it's the rot issue and partly the weight. If you're going to use a particularly dense hardwood, you'd like to get the strength of similar weight hardwoods, of which the reds suffer slightly. If it's weaker and rot prone, most just select a better suited species. I hope this helped
