I removed the complete drive unit and replaced the gimbal bearing. While handling the outdrive nothing seemed amiss. It sat off the boat on it's side for 24hrs. When I picked it up I had outdrive oil leaking down and out of the prop. Strange that it sat there fine and then started leaking at the last minute. I did not touch the ujoints or any seals as I had replaced the impeller etc a week ago. Used it once (that's when I figured out the gimbal was bad) no leaky until just now. Any ideas?
