rmurray
- Joined
- Apr 17, 2007
- 126
I am getting a lot of black dust under the engine cover and on the front of the motor. After reading several other forums, it appears to be belt dust. I can see the outer edge of my belt is a little bit frayed, so I’m sure that’s the issue. My power steering pump pulley is rusted and very rough around the edges. Everything else seems OK, so I am hoping this is the issue. I was able to go to my local Auto parts store and pick up a Dorman 300–200 Pulley for $20. It is an exact replacement for the factory pulley even though you will not find any cross-reference to the part number. I was able to use a loaner pulley puller to remove and replace the pulley in less than 15 minutes. I thought I’d throw it out there just in case anyone is having similar issues. I have a 2004 GXI.
