Black Max 150 Lower unit drain
Vking_84
I winterized my "new to me" black max v150 xr2 for the first time and came back to the barn this year with gear oil all over the floor. I am not sure if there is supposed to be a nylon washer or o-ring on the drain plug/screw. either that or I need to work out more and tighten it harder!!
can anyone help me out?
gss036
Re: Black Max 150 Lower unit drain
Definately should have a sealing washer in front of the screw. It needs to be tight, but enough to where you can't get it loosened for service again. "DON"T OVER DO IT"
Barnacle_Bill
Make sure there is one on the vent screw too. Replace them every time you change the oil. Its very cheap insurance against water intrusion.
