Larry Tate
- Joined
- May 17, 2011
- 111
Hey guys got a 89 175 hp black max, I had it out the other day and I had noticed while the cowl was off some gas was spitting out from behind the fuel pump (square type). It seemed to have some force to it and it was pulsing, like it was being pushed out. I have noticed a fuel leak somewhere under the cowl before, but the primer ball gets very stiff with no lines or gaskets leaking under pressure. So when I got it home I took the pump off of the block real quick to inspect. I found that the back of the fuel pump has a hole, with no gasket, that mates up to another hole on the engine block. I'm assuming this is the pulse from the crankcase that powers the pump. My question is (and I could not find A THING on the rest of the internets about it), is there a gasket that goes here? Maybe one of the smaller fuel lines was wedged between them causing the leak, I dunno. Have any of you guys ever experienced this? Any help is appreciated guys.
