CaptainPuget
- Joined
- Sep 29, 2002
- 137
I have a recurring problem with a 1991 Mariner 8hp 2 cycle motor. There are two holes on the back of the mid section under the power head. The hole on the starboard side is about ¼ to 3/8 in diameter, the hole on the port side is smaller, maybe 1/16 in. A nasty secretion of black ooze runs out of the small hole that appears to be a mixture of oil, water and carbon. The little hole is usually plugged with this mixture. I've tried cleaning the hole, blowing it out with air, vacuuming it out, soap water, solvents, etc. but there seems to be no end to the ooze. I believe the larger hole is an exhaust vent for pressure equalization but I have no idea what the small hole is for and the manual makes no reference to it. I'd like to find the source of the ooze and put a stop to it but I don't know where to start.<br /><br />I also own a 1993 Merc 8hp that has the same the two holes but it doesn't have the ooze problem. I treat them identically, same gas, same oil, similar usage. <br />
