Black substance coming from prop
TruDaddy
Black stuff coming out by the exhaust/prop, and it appears to be overheating. Ran it at 1500 rpms on muffs and it wanted to stay at temp halfway b/n 145 and 220.
Bt Doctur
either the engine is burning oil, there would be a lot of smoke or the outdrive oil is leaking, or it was heavily fogged down for winter.
stonyloam
If it is running hot, that indicates you are not getting enough cooling water into the exhaust, and you might be burning up the rubber on the shutters and bellows, or it is running rich. In any case the overheat indicates it is time for a new impeller.
