UKMike
- Joined
- Apr 15, 2015
- 55
Hi all,
I have just rebuilt motor after snapping the main steering arm and as a result of this damage I decided to replace the lower unit bearings, added a new exhaust plate and a carb rebuild, but since getting her back together she's not running right. The lower unit seems smooth and the engine runs OK on idle, but when I took her out onto the water she was not running right and felt as though she was either flooding or being starved of fuel. Now I checked all the connections fuel wise and they are all correct, I also added new bleed valves and pipes while she was in pieces (one at a time) and also added the bleed restrictors called up on Service Bulletin p/n 823829. The problem I am seeing is that on idle and not in drive she seems to run smoothly, a little lumpy but nothing out of the ordinary, but when I put her in the water and put her in drive she feels as though something is knocking (about 1500-2500 revs approximately, or the best way I can describe it is like one or two of the cylinders are not firing or that they are flooded, I say this because if I start moving forward I get to about 2200 revs and the engine is clearly not firing correctly and when I push the throttle forward all the way nothing happens and she holds back, she gradually builds up speed until the revs pickup enough to engage the main jets and all of a sudden she bursts forward and runs perfectly.
Does anyone have any thoughts on this?
I can show her running in idle if you want to see what I mean, she really is quite smooth on idle, probably more so than ever before..
