blackmax 175hp removal
flip321
hi need help removing 2 ram tilt and trim blackmax 175hp not sure which way the top pins 67694 come out do they pull up or do you need to knock it through with thanks flip
dingbat
Comes out either side.
Mine was fairly easy to remove once I got the retaining clips out
flip321
thanks for your help but was yours a 3 ram system as the 2 ram system boest seem to have clips see no 2
dingbat
one tilt and two trims
flip321
does any one have 1965-1989 Mercury-Mariner 90hp To 300hp Repair Manual the page i need is for the removal of rams
flip321
thanks i can see that they pull up so i will need to make a reverse puller to get the pins out
