Blew the coolant hose from thermostat housing to water circulator / starboard riser hotter than port side- Do I need a new riser or circulating pump?
srubeck
Hello, thanks for your help in advance. I have used the forum to solve many problems but this is my first post. I have a 2006 Four Winns 348 Vista with dual 5.7 GXi-G motors with 320 hours on them. We have owned the boat for 3 years and never had a problem with the engines. The boat has been in fresh water in Lake Michigan in lower Wisconsin most of its life and we have had it in Lake Geneva the last 2 years. We are having 2 similar problems lately on different engines:
1. 2 weeks ago my starboard engine burst the coolant hose from the thermostat housing to the water circulator. I took the thermostat housing apart and found impellor chunks clogging the bypass hole. I have cleaned this out and the engine is back to normal except I am getting a whining noise in our water circulator. It seems to quiet down after 10 minutes at idle. I just wanted to check if the strain from the clog could have done damage to the water circulator and if I should replace it. The coolant hoses do not seem to have pressure on them since the clog was removed and the engine is running normal and has good temperature.
2. More urgent issue- About a week after the fist engine, I had a similar problem with the port engine. When I changed the thermostat on the first engine, I also did the 2nd engine (should have left it alone I guess). After I changed it and did a test drive to check it, the thermostat fell down. So we ran back to the marina and put the thermostat back in. I must have had some rust in the o-ring groove. I cleaned it out and the o ring held fine after that. The boat ran fine for 2 days (just normal drives or 30 minutes to an hour, nothing hard on the motors), then I started it up the next day and was motoring around the marina and blew the same coolant hose from the thermostat to the circulating pump. I have put it back together and can not find a clog. The hose is pressurized still and it seems that as soon as I would get up to 2-3K RPM it will blow. Seems like there is a clog. Also, I noticed that the starboard riser is much hotter. Here is what I have checked already:
a. taken the thermostat housing apart a few times and it is clean of impeller parts
b. I have taken all the hoses off from the raw water pump to the hoses going to the risers and cleaned them and made sure there were no clogs.
c. I have checked the raw water impeller and it looks good (replaced this March)
d. I have pulled the riser plug and it has good water coming out of it at idle
e. I have pulled the starboard riser and checked it for clogs. It looked really good and I did not see any blockage. I sprayed water through it with a water hose while it was off and it seemed to have good flow and the water came out. I also sprayed penetrating oil into the water jackets while it was off thinking that it might have blockage inside of it that I could loosen up. I was thinking that if water can get through it then it should not be blocked. But based on it getting hotter this seems like it would be the problem. Based on the appearance it does not look bad. Has anyone had one go bad inside that you cannot see the obvious problem. I am not sure if you can pressure test these.
f. I have detached the hose going to the starboard riser at idle and it has a good stream of water.
g. The water pump starts to whine after 30 second at idle. Seems like the pressure is causing this.
h. I have followed all the hoses at idle and they seem to be fine with flow. The large coolant hose is the only one under pressure.
i. I replaced the thermostat thinking maybe it was damaged when it fell down during the test drive.
j. I don't think the engine got too hot when the hose blew. It starts up fine and runs well. But I can tell the hose will burst with any load on it.
Thanks for your help. These issues are strange because they happened so close to each other. I am debating throwing parts at it and thinking it is either the riser or the circulating pump but wanted advice on if I am missing anything or something to check. It must be a clog causing the pressure but I can't find it. Here are pictures of the risers.
srubeck
Has anyone had any experience with a Riser that looks good being clogged on the inside? Water goes through it but not sure if there are restrictions that I can not see.
itsathepete
If you remove hoses from the manifolds or pull riser plugs and run the engine, does the circulation pump hose still pressurize?
srubeck
Thanks, I will try that tonight. I had removed both but I did not pay attention to the pressure as i was looking for the water strength coming out of them. Thanks again and I will report back.
Lou C
Make sure that you have no rust clogging the outlets in the stat housing that feed the manifolds, and that there are no impeller bits in the hoses that feed the manifolds, esp the one with the hot elbow (riser).
You might try:
clean the outlet ports in the stat housing, blow thru the hoses. Then hook up the hoses to the stat housing and briefly start the engine to make sure you get about the same flow out of each side.
Your exhaust parts look immaculate, at least for me here in the Long Island salt pond! If we get 5 seasons out of a set of elbows we are doing well! I'd be surprised if there was any clogging in those parts.....
If your circulation pump is whining the bearing is going bad and will start to leak behind the pulley. Replace it they are cheap and its an easy job. No need to buy Volvo OE just get a Sierra pump. I've installed a few over the years.
srubeck
Thanks for the help. I removed the starboard manifold hose and checked the pressure on the large coolant hose and it still appears to be there. Is it possible that the water pump is causing high pressure if it is bad? I’ve checked the thermostat housing really well. Also I pulled both manifold hoses off. When I do that the starboard hose stops pumping water. Then when I put the port manifold back on the the starboard has water flow.
srubeck
I am wondering if the circulating pump is not moving the water pumped by the raw water pump and causing the pressure. Is that possible?
srubeck
I changed the circulating pump and it did not make any difference with lowering the pressure in the hose. I am wondering if there is a clog with the water coming into the engine or maybe with the impeller. I am able to see water flowing through all the hoses from the raw water pump to the manifolds. The water is not shooting out of the hoses very strong but they are about half full and it appears to be a steady stream. The engine is not overheating but the stream of water does not seem strong enough to go to both risers. Seems like the least path of resistance is on the port side as the starboard side is not getting water and gets hot. If I just take off the starboard manifold then water come out of that hose. Does anyone have experience with how to check for clogs on the water coming in or maybe a clog on the water going out past the bellows? Could that create this pressure? We had some trouble with our power steering recently and I am wondering if there might be a clog in the cooler and if that would cause pressure issues. Thanks for your help. Sorry for all the posts, I am hoping to get this fixed before the weekend.
itsathepete
Is the hose pressurizing at all times or only at higher rpms. Does it do it when the engine is cold and hot or just when cold?
srubeck
Seems to be all the time. I have not ran it much more than idle but I am assuming at higher rpm the hose would blow
itsathepete
If you pull the thermostat and run it and there is no pressure then the problem is in the thermostat housing. there is always flow to the manifolds when the thermostat is closed. If there is a restriction it can cause pressure.
srubeck
Thanks itsathepete and Lou C for your help. I wanted to give an update. I went back through the system a few more times and finally discovered that my bypass hole in the thermostat was clogged. I had thought the by pass hole was the connection between the large hose and raw water inlet hose openings in the housing and was not aware of the smaller hole in the raw water inlet that goes past the thermostat. Once I removed this clog everything was back to normal and I was happy. It was a rookie mistake but I learned a lot about the coolant system, which will be helpful in the future. Thanks for your help and advice as I was trying to figure it out.
Lou C
here's some pix to make it easier to understand
