I have a couple questions about installing the pistons on a 150p V6 Evinrude. Most of my rebuild background is v8 autos, but I want to make sure that I get this right.<br /><br />1. I need to use some form of grease to make sure that the pins in the wrist pins stay in place while I replace the pistons. Can I use white automotive assembly grease for this?<br /><br />2. Is there anything special that I should do when putting the pistons in for lubrication of the cylinder walls when installing the pistons? I figure on wiping the cylinder walls down with a light coating of 2 cycle oil, but is this sufficient for initial startup?<br /><br />Mik
