tango13
- Joined
- Mar 10, 2015
- 75
Hi All,
Like most boats, mine is a major PITA to winterize. I have to remove my whole rear bench interior, just so I can crawl in to drain the block plugs on the old 350. I would really like to set it up so I can simple reach into the engine compartment to winterize (also planning to relocate oil filter).
I have been searching for a way to make my own ezy drain system for this old mercruiser setup (1977 "250hp" 350ci), and I found this drain assembly kit for a air compressor that I think might work:
https://www.amazon.ca/Hromee-Extend...ank+drain+assembly&qid=1600381346&s=hi&sr=1-2
I would install it without the 90 degree elbow (so I can reach in with a coat hanger incase I get a blockage), and have the ball valve at the end, hanging out so I can simply reach in and open the valve come winterization time.
All the pieces are brass and stainless, so corrosion shouldnt be too much of an issue.
Does anyone see any reason why this wouldn't work?
Thanks
Thanks
