scottberry
- Joined
- Jul 3, 2009
- 20
The other day the boat wouldn't start. I finally traced it down to the 15 amp fuse in the ecm box on top of the motor (5.7 mercruiser). There are three fuses in the lid of the box that have two 15 and one 10 amp fuse. This fuse seems to power the fuel pump and the audible alarms. I replaced the fuse and everything was fine for a day. The next time out the boat started at the ramp and ran fine for an hour or so. When I tried to start it after some skiing, it toasted another fuse. I replaced it and it worked fine for the rest of the day.
Today I was trying to troubleshoot the issue. Now everytime I turn the ignition to the first position, the fuse blows. I traced the two wires from that fuse and they go to a pink with red stripe and red wire. the red goes to the coil and the pink branches out to the water temp and drive level sensors and then goes to a module called ECU that is inside the black box.
Any thoughts on what is tripping this fuse?
