svillebrian
- Joined
- Jun 29, 2008
- 41
Just recently started having a problem blowing the main fuse located in the wiring on the motor. I have a 2001 Johnson 90hp 60 degree. I put a test light on the fuse plug, and getting power to one side of the connecter and the other side is grounded, causing the fuse to blow. My main question is where do the two red wires on the fuse connector go (or tie into to) so I can try to trace where the one side of the wire is grounding out? Any help is greatly appreciated!!
