Blown fuse - or something worse?
threedogs333
I know, i'm stupid but it was an honest mistake. I accidently put the pos+ on the battery neg- and the neg- on the battery pos+, but it was dark and I was tired. I couldn't figure out why up on the trim was going down and vise versa, and then I realised what I had done. Changed them around the right way, the motor starts and runs and the trim works fine, but the trim gauge and the volt meter don't work, have I popped a fuse, a relay or is it a six hundred million dollar repair job.
5150abf
Re: Blown fuse - or something worse?
You don't say what engien you have but yes there are generally fuses under the hood, they are in enclose red rubber housings and I woudl suspect that is your problem, you may have smoked you rectifier though.
