modrealtor
- Joined
- Aug 11, 2007
- 10
My first post after finding this site. Thanks for providing such a service. hare's my motor number VJ175GLETG. It's a 1993 175 Fast Strike on a 1989 Bayliner Trophy Center Console. Here's my problem. I installed a ten inch
TH Marine Pro Hi-Jacker. Upon raising the assembly approximate 4 inches, I was going head to the local lake. i tried raising the motor using the switch at the motor to set the motor back to its cradle. No response. So i lifted the motor cover and checked the fuse. Yup blown. Replaced the 20 amp fuse and tried again. Dam, blew the fuse again. So I checked around the motor thinking it could be a crimped wire I never saw. The only two wires are the ones inside a fabric covered tube. It goes to the the box which has a single plunger which rides on a cam. The cam rides on cross shaft under the motor frame. It looked OK and was far away from being pinched. I then removed the three wires from the motor switch and tried from the console switch. Again blown fuse. I replaced the three wires to the motor switch and removed the three wires from the console switch. Went back and tried the switch from the motor. Again blown fuse. I then replaced the three wires to the console switch and removed both relays since the three wires were part of the five wires. Tried again with both relays out. Another blown fuse. I replaced both relays and un plugged the five pin plug this time. I went back to he motor switch and depressed the up button. Hurray it worked without blowing a fuse. So I've eliminated both switches, relays. What does the other wires go to which is causing me to blow the single 20 amp fuse. I need help now.
