Blown Fuses
byr0n
I have a 1979 Campion with a 302 OMC inboard motor, and OMC Sterndrive at ramdom times the motor will die, when it is put in forward gear, the only way to get the motor running again, is to replace the blown fuse, and when put into forward again the motor and the same thing will happen again. reverse gear works fine.
Re: Blown Fuses
Ayuh,...
You've got a Dead Short,....
Broken, or Chafed wire naybe,..??..??
