I did a compression test and the results indicated a blown head gasket. I removed the head and sure enough the seal between 2 and 3 was blown away. I am going to the marine store to get a new gasket. However while I had everything torn apart I wanted to make sure everything else was good. I am not 100% sure what I am looming for but the piston walls actually look mirror shine. From the feel there are no gouged spots. I took lots of pictures but I think I cant upload them from my phone.
So a few questions.
1- what is the best tool for removing the gunk, and other stuff that cant be removed with liquids? Is there a tool I can put in a power drill, or a certajn type of sand paper I can use?
2- the boat ran rich for a while so everything has lots of carbon build up. What can I use to such as the valves and pistons. What can I use to get all the carbon off of the surfaces?
3- the gasket that was on the block looks like it is made of tin or something. Are there different types of material they are made out of and if so are certain materials better than others?
thanks all.
So a few questions.
thanks all.
