swampy2646
- Joined
- Sep 19, 2009
- 67
i recently repowered with a 5.7 long block in a 1991 maxum 2500 scr. i put an agressive cam(300 hp) with a new high rise intake, a rebuilt q-jet, new risers and manifolds. upon initial test run, the head gasket blew between cyl. 2&4. after 10 mins. the builder claims the engine was running lean. i pulled the head and sent it to a local machine shop to be checked out. i pulled the other head and changed both head gaskets. after having other problems(previous posts) i got the engine running great. last week it started to run a bit rough and sputter. i did a compression test and found : 2 (50 psi) 4(50) 6(90) 8(150) the other side was within specs. i didnt pull the head yet, but im assuming the gasket blew again. is it possible to be running lean, the plugs looked good and there is never any pinging. if so what causes this condition?
