Hey iboat guys - I'm new to this site but so far it seems like most of you are very knowledgeable about this stuff so maybe someone can help me out. I just bought a 97 Crownline 182 with a 4.3lx gen + (according to the cover). Got it for cheap but am realizing you get what you pay for. I launched the boat in Lake Ontario last night and it started quite easily. Let it run for 3 min - no reading on the temp guage, oil pressure at 40 (psi I think). Blue smoke started to appear from the stern area. Left the dock and headed out the harbor, no temp, oil at 40. Pushed the throttle to full and only achieved about 25mph at approx 4500 rpm. Looked back and saw a trail of blue smoke and more coming from the stern. Stopped the boat, temp at 100 and oil pressure low on the gauge (not sure exact figure). I opened the engine cover and smoke was coming out from everywhere including the hoses from the valve covers to the carb and inbetween the exhaust mainfolds and heads. I think it was overheating as it sounded like water boiling or popping and the engine felt hot. With the key on the temp now only reads just over 100. After being towed back in I started the engine again easily and checked oil pressure at 30 or so, temp just over 100, less visible smoke. I did remove one of those little blue drain plugs under the port manifold and ran the engine - no water came out at all. I also noticed the bilge was filling with water (i think from the bellows, the shifter one is ripped in half) and a pure white substance which seemed to be coming from the port exhaust manifold rubber connection to the outdrive. I shut the motor off and checked the oil which is golden in color and looks new. Any advice on what is going on with this thing would be greatly appreciated. Also where can I get a shop manula for it. Thanks guys and have a good one!
Steve
Steve
