boat anchoring
macie
is it recommended to have a chain attached to an anchor vs just having a nylon line attached thanks in advanced
partskenn
Re: boat anchoring
Yes, helps the anchor lay down on the bottom, keeps it from getting yanked off the bottom as your boat bobs up and down. Somewhere between 6 and 10 feet of chain depending on yor boat, anchor, etc.
spoilsofwar
Re: boat anchoring
It makes life easier, or is absolutely necessary, depending on the conditions where you boat.
I have 6' of vinyl coated chain on my smallish boat's anchor line, and my anchor has never given me any problems due to dragging.
QC
Re: boat anchoring
I like at least half of boat length, and preferably a boat lengths, worth of chain. Makes a HUGE difference with most traditional anchors. Also, don't forget scope. With more chain you can lessen scope some, but you should try and have 5:1 - 7:1 scope. That's length of rode (combo of line and chain) compared to depth. 10 ft deep = 50 ft. rode (5:1 scope).
CaptainKickback
Re: boat anchoring
Chain also provides protection from rocks and other sharp objects.
Sea ya...
fiberformak
Re: boat anchoring
it also helps to pull up a long line and heavy anchor by being able to put on a buoy and pull the anchor up. As you back up the chain on the end will slide through the bouys ring and then the bouy will stop at the anchor. when you stop pulling the chain length that has come through the bouy ring falls down holding the anchor in place as you wind up the rope. We anchor in deep water so i would have to pull up the anchor by hand. keep in mind though any amount of chain you have is just one more thing to rub on your boats fiberglass.
