I have a 1984 Black Max 150 HP. have had boat for quite a few years has run great then started this bogging down thing. Did some trouble shooting found a broken reed valve replaced it. Always had a little back carb spit at startup reed valve seems to have fixed that. Motor starts real good, ideals good but when you put it in the water and throttle up motor would still bog down. Would have wifie go to front of boat if you get lucky get enough RPM's up the boat would get out of hole and run at top speed. Did more research things was pointing to the stator so i said what the hay bought new stator and while i was in that far went ahead and replaced switch plate too. Took boat back out to lake no fix still bogs down. Need some pointers on what to do next? what gets me the most is when you get lucky and get it on plan runs great can go 65 MPH shoot rooster tail all you want. Put boat back down in water good luck on getting it back up. Need Viagra or something?
Casey
Casey
