Boat Buying Angst
Tony Van
Years ago my wife and I owned a 28' Luhrs with a glass hull and wood topsides. Eventually, replacing rotted wood in the cabin sides got to be too much of a chore and we sold the boat and took up camping.<br /><br />Having our fill of that,we want to get back to boating. Our only requirement is that the boat be fiberglass with no wood. <br /><br />When I starting doing some reading and research, I found that a solid glass boat, like my old Luhrs, is a thing of the past. <br /><br />Worse, I was seeing stories of water-soaked cores, rotten floors, pulpy transoms and hulls coming apart in a seaway. I almost have convinced myself that a wood boat would be a better choice since it is repairable without removing an outer skin!<br /><br />Am I being foolish here? Are the problems with saturated cores, delamination and blisters only occuring in a small percentage of boats, or is the problem more widespread? <br /><br />I'm trying to educate myself so that I can do a pre-survey on a boat of interest before a professional survey is done.<br /><br />Maybe some of you more experienced boat buyers or a professional can put this in perspective for me.<br /><br />Any and all advice & comments are appreciated. Many Thanks<br /><br />Tony Van
JB
Re: Boat Buying Angst
You need to check out Boston Whalers, Tony.
crazy charlie
Stick with a good brand name boat without a wood superstructure.Look at something that has been obviously maintained well,not maybe,obviously.Check out everything mechanically and cosmetically that you can and leave the rest to the professionals.A surveyor with experience in what you are concerned with. Charlie
Go with Fiberglass.....<br />Delaminations are the Exception, Not the Rule....<br /><br />Well, Except for Bayliners....
Luna Sea
I used to have a 1972 27' Silverton, sistership to the Luhrs. That was a strong hull though, but I too replaced the decks, front window area, topsides, ect. Plenty of good solid all glass boats out there Tony. Silverton makes a good boat still, if you like the camping part of it, find a late 80's or newer 32' Trojan, Silverton, Sea Ray, Mainship, just to name a few I haven't heard of many problems with... Good Luck and welcome to iboats
Stratocaster
Tony, there is a lot of good advice on this board. As long as you ignore bondo the troll.
RicksAmigo1
What are you going to use the boat for? Fishing, cruising, ? Wood is beautiful, but too much work. We've had no problems with our fiberglas boats. We just bought a new 22' C-Dory cruiser for fishing, cruising and camping out on. We are going to sell the 1989 22' Boston Whaler, cuddy cabin which is set up mostly for fishing. We hate to part with the Whaler, it's a great boat, but it's not practical to keep two boats.<br /><br />Pat and Rick
Northern Eclipse
Tony Boats I see that have rot in the floors and stringers are the same boats I see sitting in the elements summer and winter that have been poorly covered or not covered at all and they are also the same boats that have baffed interiors and Sun damaged gelcoat....so If it looks bad then it probably is... If boat looks clean and well cared for rot should not be a factor, as for builders quality I tend to notice that most cases of rot from builders shortcuts can be found on boats from mid to late 80's, I'v read that many builders fell into this catagory at that time because the price for resins and other building materials skyrocketed, thus builders tried to cut production cost, at the expense of quality....but todays there are newer building methods and materials, If you buy a good boat to start with and take care of it, It'll stay good, If buying used always get a professional survey.
