archcityBob
- Joined
- Nov 21, 2010
- 52
Hi. I'm still looking for a boat to buy and reading old threads.
A couple of questions ...
How do I know if the boat has water logged foam if the deck is basically solid?
Hooking up muffs to an engine to test it. Turn the water on before or after the engine is running? (A guy at work maintains he filled his cylinders with water on a Waverunner by turning on the water before the engine was running.
Compression testing. Can I use a compression tester from Wal-Mart or Auto Zone? Then just bump the engine to get the readings?
Are there standard size threads on the spark plugs for the compression tester to thread into?
Will an automobile spark plug wrench fit on a outboard plug to remove/tighten it?
Why is it that when I didn't have any money there were numerous boats on Craigslist that seemed to meet my criteria. Now that I have cash in hand they are all gone.
