Boat capacity plate
Mettaree
I am considering purchasing a 1995 Neptune 200CC and the capacity plate is missing. Need to know max HP and max load. Am in Louisiana - will LDWF frown on a boat with no capacity plate? Boat does have S/N plate. Registration no problem.<br />Thanks in advance for any info anyone can furnish.<br />Fair Skys
roscoe
Re: Boat capacity plate
If you post the first 3 letters of the hull ID, I can identify the manufacturer, and hopefully get you a phone number and address for them.<br /><br />Here is a quote from the USCGuard site.<br />"NOTE: The Coast Guard Capacity Information label is required only on monohull boats less than 20' in length."
ob
Here's a tidbit from the NADA site on your boat.I'm assuming that the 130 hp entry is the max rating.Boat was manufactured by Sunbird boats which is no longer in production.<br /><br />Length: 20' <br /> Model Name/Description: NEPTUNE 200 CC(*) <br /> Boat Type: Outboard Boats <br /> Hull Material: Fiberglass <br /> Beam: 7' 8" <br /> Engine: 1<br />130 HP<br />Gasoline <br /> Net Weight: 2,085 <br /><br />--------------------------------------------------------------------------------
Mettaree
roscoe and ob: Thanks a million for your quick responses.I'll try to get those numbers as a second check. I've seen some pictures of that model (later year) with a 150hp. Once again many thanks. Ya'll are what this board is all about!!!!
