Pbdy Jr
- Joined
- Apr 14, 2013
- 30
PLEASE HELP!! Boat starts and runs in driveway.In the water,does not want to start.
Okay, so this season my boat decided to give me a hard time... I was out on the lake as normal and when it was time to come in, i pulled up my anchor and went to start the motor.... It just kept turning over. Eventually it started, It ran fine, no sputtering, misfires etc... I got it on the trailer and took it home. Hooked up hose and it started right up. Changed plugs, wires, dropped the lower unit on the Alpha 1. Impeller is practically brand new. Still fires right uo in the driveway. Brought it to the water and same thing.
What is causing this to not run right in the water?? while it turned over i sprayed some engine start spray and that did nothing. carbs clean, fuel flows fine. no wiring issues can be found.. When the boat is in water, the only thing I can think of is the water creates pressure which is effecting something... but what??
Mercruiser 3.0 with Alpha 1
