stourm
- Joined
- Feb 21, 2009
- 48
My 1980 ProCraft bass boat has a metal ring (insert) at the drain hole to allow you to install the drain plug. It has gotten to the point where the plug is difficult to put in and I think some water seeps in around the plug while in the water. While shopping at Gander Mountain I found this nifty little device, which is a plastic insert that you screw into place and has a plastic threaded plug with an o-ring attached. Here is a link to the one I purchased, although not from the Gander Mountain website.
http://www.boatingsavings.com/net/cb/cb.aspx?a=431495&kwtid=279017
I liked the design for a couple of reasons. First, the plug, once unscrewed, will hang there at the back of the boat and won't get lost. Secondly, the o-ring design should stop water from seeping into the boat. The problem that I have is that I need to remove that metal drain ring in order for this dude to fit. I don't know how to go about safely removing that metal ring...if it is even possible. If anyone has any ideas I would greatly appreciate some suggestions. Thanks.
