mrlassi1
- Joined
- Aug 30, 2009
- 97
Wanted to pass along information about my boat dryer. My 19' I/O is carpeted and stays under cover when not in use. I needed a way to get the moisture out, but keep additional moisture from getting in. First I added a vent on the support pole. The circulation from the vent alone didn't do much good. Looking around my shop I found a high volume NuTone bathroom exhaust fan that was not being used anymore. The fan has a 4" exhaust and good air volume movement. I added a electrical plug pigtail, a couple of support blocks and some casters. The air is directed under the cover using a section of 4" flexible drain pipe. This configuration is almost silent when in operation, uses little electricity and dries the boat out quickly.
Information from the Forum has very helpful to me over the years, hopefully this post will help someone with a similar need.
