So I just opened my boat for spring I have a 2003 Stingray 180 with a Mercruiser 3.0.
I changed the plugs, flushed the coolant out from winter and changed the oil. I have two batteries and they have remained plugged in to a battery tender when not in use. After I did the tune up I started it up and it cranked up and ran perfectly. I checked the blower and the bilge and the lights and all worked. The blower works independently of the ignition switch. After letting it run awhile I turned the switch off. The next day i went to check it again, turned the blower on and nothing, only heard a sound like the speakers were turned off/on . Same thing with the lights and horn. Heard a sound through the speakers. Turned the ignition and same thing Im hearing a sound in my speaker for a split second after turning the switches or the ignition but there is no power to the blower, lights and the engine wont turn over. What is going on??? Any ideas?
