So we dug in to her today. I learned some things:
#1: My circular saw is jacked up and can't seem to cut a straight line for ****.
#2: No matter how hard you try or where you put the nozzle of the vacuum dust will end up in your underpants somehow.
#3: A fine toothed saw blade is NOT the correct blade to cut through a fiberglass floor.
I made some rather interesting finds though. First and most importantly, MY STRINGERS ARE FINE! YAY! They're fine because there is ABSOLUTELY NO WOOD IN THEM. They're made of fiberglass and filled with foam which is somehow dry as a bone. So I will not be replacing stringers. This, dear friends, is a good thing because my boat partner (Wayne for future reference) has already had a boat with bad stringers. As a matter of fact, he refused to disconnect the trailer from his truck until we cut out the back to check the transom and stringers due to the previous experience he has had. He was adamant that if we had to gut the hull it was off to the landfill tout suite as not to become another flowerpot in his back yard.
I do, however, have a butt-ton of partially waterlogged flotation / support foam. I need to find out what density it is though. and I'm not sure how other than somehow removing exactly 1 cubic foot of it and weighing it. I need to have someone that knows this stuff actually look at it I guess.
So, an engineering question now. Is there some really good reason that they didn't make some kind of provision for water to escape these cavities as they would almost inevitably get some moisture in them? If it's just to save cost or something, should I then rectify the situation?
Another question, is there some way to seal up the foam to avoid this happening again? I'm imagining the silver bags that are sometimes used in shipping to create custom form-fitting cradles for things inside of boxes but on a larger scale. Imagine if the foam was allowed to expand inside a plastic bag and then sealed. I'm not suggesting that I do this with a kitchen trash bag as I have no idea how this stuff will react with a hefty bag, not to mention that the resulting reaction is exothermic and I would rather not fill my boat up with melted plastic, but you get the idea. Is there a way to accomplish this or should I run over to the patent office tomorrow?
At any rate, here are some photos.
And Wayne in full haz-mat gear (minus the goggles).
